corestar
Contributor
5 years agoOdd NIOS C++ compiler behaviour
I'm using Quartus 18.0 Std and the NIOS SBT for eclipse. I have a header file called util.hpp which should be treated as C++. But all C++ code in the header is flagged as a compiler error as in cpp_e...
EricMunYew_C_Intel
5 years agoHi, David
you can try enable_c_plus_plus in BSP under Main->Advanced.
