20 years ago
Number of clock ticks required by scheduler
I would like to know as to how to determine the number of clock ticks taken by the eCos scheduler itself for the NIOS II processor?
Is there a standard number or do we have to calculate it using the clock functions?
Thanks in advance.
    Following the eCos mailing list
    To run the tm_basic test, I compiled the tm_basic.cxx file separately.
    Thirst I builded the ecos library with nios2configtool
    Then I created a “tm_basic” application with the NIOSII IDE, I copied the tm_basic.cxx file and created the appropriate makefile then build & run.
    Hi GLecordier,
    Thanks for your response about how to use tm_basic.
    I tried using the same method, I created a NIOS II IDE project incorporating the tm_basic.cxx file and downloaded it after downloading the NIOS II processor using Quartus II 5.0. However, I was not able to see any output on the console.
    Are there any other settings required to be done?
    Thanks in advance.
