20 years agonothing out to uart,help me
hi,Hippo you have to select nios serial in kernel config CODE [*] Nios serial support [*] Support for console on Nios UART I have select it ,but still it do...
20 years ago --- Quote Start --- originally posted by scut_ak@Apr 26 2006, 07:19 PM hi,hippo
code
[*] nios serial support
[*] support for console on nios uart
i have select it ,but still it does not work foe me.why?
have you checked my ptf? i do not know whether there is some mistake.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14701)
--- quote end ---
--- Quote End --- I found both uart_0 and uart_usb in your ptf. 1. since you have jtag connector on your board for download, use jtag uart as a first test to make sure the kernel start up. 2. use only minimal ptf, with only one uart_0 . use zImage instead of vmlinux, becaue zImage will print a message driectly to the uart port.
