22 years agoNot enough memory + ISS Problems?
OK, I have one or two problems. One, in our Nios 2 design, we have used all of the M4K memory blocks so we can't add in the JTAG debug module. This means I can't download code from t...
22 years agoKerri,
First of all, thank you very much for the reply. Now, prior to reading your last post I had made some changes to the syslib to raise the debug level. After reading your post, I started the debug going and lo and behold, it worked. So, I think there may be a problem with the IDE recognizing when the syslib needs to be rebuilt. Because I didn't change the reset address. In fact, I didn't change the hardware configuration at all. So, again thanks. It all seems to be working now. Now on to my EPCS flashing problems...
