ashutoshsriram
3 months agonot able to use multiple niosV cores at the same time
when I run ultiple niosV cores at the same time im not able to acess each of them even though i am able to detect them , i am faced with even though detecting gives me and i am unable to ...
ashutoshsriram
3 months agoThat was the wrong qsys file the original qsys file had the reset port connected to the main clock reset only, was there any specific reason that you had to use the pio from niosv/m as a reset for the noisv/g? Can multiple softcores be connected in the same architecture? As connecting both nios through a reset bridge and normally to the clock reset didnt work and gave the same error.
- tehjingy_Altera3 months ago
Hi All
I would like to share that I have successfully tested version with Quartus 26.1, and it is working as expected.
In my design, I have two NiosV instances instantiated in my design, and the Ashling IDE is able to detect and select either instance without any issues.
tehjingy
