12 years agoNot able to factory restore my board
Hello There,
I am not able to restore factory setting on my board , i am following the instruction given in nios dev. board ref. manual , i am not able to restore my board on factory setting. the steps i am following. 1. Open the Nios ESDK Shell 2. Chnage the directory to c:/altera/quartus50/example/factory_recovery/nios_cyclone_1c20 3. type the command "./restore_my_flash" please see that attached output of my shell. and help me out how do i overcome from this issue i have also attached my Environment Variable Setting also for your reference kaushal1 Reply
Quartus 5.0 ! It is a April 1st joke ;-) ?
Hi, it seems your Quartus installation has been corrupted. You have Quartus 5.0 and Quartus 9.1SP2. You "SOPC_BUILDER...." environment may be corrupted : the "+" is suspicious, the paths should be separated by a ";" Try to redownload the Factory Flash through Nios II IDE.
