16 years agonon-optimal address decode logic
I'm trying to assign some sane addresses to memory and I/O blocks.
Whenever I put 'tightly coupled' code or data at a lower address than the general code/data master I get a warning about non-optimal logic. This happens when there are only 2 slaves (one on each master) and the addresses could be split using a single address bit. The design has several tightly coupled code and data blocks (2 Nios cpu), some IO accessible through the data master, and a 16MB SDRAM for buffers. There is no data cache, the instruction master (+cache) is only present in case we want to use the JTAG debugger. Ideally I'd like to setup something like: 0-64k: tightly coupled code. 64-128k: tightly coupled data. 128k-256k: I/O 16M-32M: SDRAM. So that the layout is resonably independant of the size of the SDRAM. %gp would be set to the 128k boundary, so that much of the data and I/O can be accessed with %gp relative instructions. But the SOPC builder complains unless I put the SDRAM at address 0.No RepliesBe the first to reply
