11 years agoNon blocking getchar() with Fifoed UART
Hello, I am using a Fifoed UART for reading characters from the serial interface. I found that getchar() is blocking when no characters are present in the fifo which I cannot use. Is there ...
11 years agoHello,
When I run the below code and type some characters the first line its reports the number of characters in the fifo and than reports that there are zero characters in the buffer. This seems strange to me because I am not reading any characters from the buffer. while ( true )
IOWR_ALTERA_AVALON_TIMER_SNAPH(TIMER_0_BASE, 0);
if ( IORD_ALTERA_AVALON_TIMER_SNAPH(TIMER_0_BASE) == 0 ) // timer overflow
words_in_fifo = IORD_FIFOED_AVALON_UART_RX_FIFO_USED( FIFOED_AVALON_UART_0_BASE );
printf("\r\n%i words in fifo, getting character\r\n", words_in_fifo );
IOWR_ALTERA_AVALON_TIMER_PERIODL(TIMER_0_BASE, 0);
IOWR_ALTERA_AVALON_TIMER_PERIODH(TIMER_0_BASE, 5000);
IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE, 0x04);
putchar( XMODEM_RWC ); // send "C"
count++;
IOWR_ALTERA_AVALON_PIO_DATA(PIO_OUTPUT_BASE, IORD_ALTERA_AVALON_PIO_DATA(PIO_OUTPUT_BASE) ^ DEBUG_LED1); // toggle LED
} Anybody with some ideas what is wrong here. I want to break out of the while-loop when a certain character is received without a blocking getchar(). Thank you, Wamor
