12 years agonon-blocking AvMM reads
Hi, I have observed that when user application tries to read from a non-existing address the uC hangs, but when doing the same with memory viewer in debug mode, it doesn't. I would assume the d...
12 years agoIndeed, you probably have to ask your FAE how to access the nios 'hidden config menu'.
It contains some useful stuff - some of which probably generates broken cpus. We found out about it because I needed to disable dynamic branch prediction.
