16 years agoNOMMU uClinux page and others seriously outdated
In effort to compile uClinux without mmu (or even with mmu), I have found the
instructions on the wiki page to be now very confusing and highly outdated. nios2-linux-20090929 does not work the same way nios2-linux-20090730.tar did everything is different in that tar file, it is a mix of MMU and NO-MMU. BTW nios2-linux-20090730.tar was the last working one, but the TSE did not work so I needed to upgrade. Are there any stable instructions for getting the NOMMU version working. The MMU instructions are not good, and only platforms that I can build now is for two Cyclone III platforms that I don't have.2 Replies
Also sopc.et.ntust.edu.tw os no more
host sopc.et.ntust.edu.tw Host sopc.et.ntust.edu.tw not found: 2(SERVFAIL) What should I use - Altera_Forum
I just saw similar discussion on thread
http://www.alteraforum.com/forum/showthread.php?t=23549 I was able to follow directions to checkout NOMMU code. I will continue on that thread
