20 years agoNoise sources
Hi folks,
i need to create some strong random numbers but for this i should have some noise sources on nios2. i could take the timer as the first source but that's not enough i think. Possibly someone of you got any idea what sources of noise i could take! thanks in advance Steffen2 Replies
Hi Steffen,
> i need to create some strong random numbers This is always a considerable challenge, no? > Possibly someone of you got any idea what sources of noise i could take. For the time being, the most reasonable source (for me) has been interrupts that are asynchronous/aperiodic in nature (e.g. uart, ethernet, etc). But that's just half (or less) of the problem: how you use them can be a headache as well ;-) Combining an async driven LFSR with a clock-based LFSR as a salt source for a crypto algorithm (the output of which is the random data) appears good -- but I never did the math 8-P Please don't be shy about posting your ideas -- this is very, very challenging stuff! Regards, --Scott - Altera_Forum
If you are able to use custom electronics, there are proven physical methods. For instance, measure the voltage on a diode with a very accurate A2D and take the LSB as a source of random noise. It should be very simple to write a NIOS driver for the A2D.
