16 years agoNo source file named....
Running NIOS 2 Software Build Tools 9.1 on Windows Vista 32bit. I recently started getting the following messages in the console:
No symbol "auto" in current context. No symbol "new" in current context. Current language: auto; currently asm No source file named laser_main.c. No source file named laser_events.c. No source file named laser_events.c. No source file named laser_events.c. the program compiles and runs fine. I know laser_main and laser_events files are in the project. the problem tho, is when i debug, since it cannot fine the source, cannot show the source code and step intelligently... I tried cleaning. Is there something I can do to get it to recognize these files? thanks4 Replies
I am getting the same error. Dont no how to get around the problem.
Are you mixing C and C++ code?
Have you files with .cpp extension, too? Check the compile settings. - Altera_Forum
Hi, I know the Thread is old, but I got the same problem. In my case, it was solved, after I set up a new debug configuration...
Very simple, but worked for me. Greets - Altera_Forum
How to setup set up a new debug configuration?give more detail would best!thanks
