no nios ii target connection
Check the project folder if there is no .elf file that means there is an error stops the making of the .elf file, in this case please check the BSP settings and the memory size.
If there is an .elf file please check the JTAg speed configuration and try to reduce it via the following command :
jtagconfig --setparam 1 JtagClock 6M
please also watch the following video which is very useful:
https://www.google.com/search?rlz=1C1GGRV_enMY756MY757&sxsrf=ACYBGNT3hX9thOGE4P9e9sGZc_0nmdNZig%3A1568254388438&ei=tKl5XdepGsPTz7sP3uq4qAI&q=jtag+configuration&oq=jtag+configuration&gs_l=psy-ab.3..0j0i22i30l9.12124.13822..14102...0.4..0.73.523.8......0....1..gws-wiz.......0i71j35i39.umUdqQlFaBw&ved=0ahUKEwjX0_XtmsrkAhXD6XMBHV41DiUQ4dUDCAo&uact=5#kpvalbx=_w6l5XY_TF7_Wz7sP2ruNiAo26
