11 years agoNo Nios II target connection paths were located.
I am trying to execute a hello world program using cyclone 2 fpga. In run configurations, after clicking on refresh connections, an error "No Nios II target connection paths were located. Check conne...
11 years ago --- Quote Start --- I am trying to execute a hello world program using cyclone 2 fpga. In run configurations, after clicking on refresh connections, an error "No Nios II target connection paths were located. Check connections and that a Nios II .sof is downloaded." appears. I have successfully downloaded .sof file onto the fpga but right after that when i click on refresh connections, no connections are shown. Kindly help! --- Quote End --- I could solve that issue... i had to set the unused pins in quartus to "input tri state". but now, after building the project in nios 2 eclipse, when I run as nios 2 hardware, I get an error saying "downloading ELF process failed" I dont know what to do. please reply if anyone has solved this issue. I repeat again, that i am trying to execute the "hello world" program. The timestamp and system id are matched. thanks in advance.
