16 years agoNo filesystem could mount root
hello:
I was trying to transplant uClinux to DE2 for two weeks,I follow the wiki step by step! and the error message is: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) After I found a lot of web page.I found the mistake was happen at romfs,because,when I do the order "make romfs",it says "nothing to do for romfs",and the romfs file is empty. When I follow this web page,http://www.nioswiki.com/index.php?title=operatingsystems/uclinux/uclinuxdist/initramfsupdate&highlight=initramfs I delete the romfs and make it again,the results is the same! I think the problem is the rootfs,but I don't know how to resolve it. I was using Ubuntu 9.10,quartus and IDE 8.1,and the uClinux-dist is uClinux-dist-20070130.tar.gz,and the my NiosII gcc cross compiler is nios2gcc-20080203,and it is successfull. I have confused it for a few weeks,but I still resolve the problem,please tell me how to do,how to build the rootfs or how to transplant uClinux to DE2.Thank you very much!2 Replies
hello,I have resolved the question,but thank you all the same!
I ran linux on QSPI flash, and met the similar problem as you did , can you show me your experience. thanks
