Naccy
2 years agoNo display in NIOS II console
Hello all, I tried the 'NIOS II Application and BSP from Template' using a previously developed sopcinfo file, but the NIOS II console showed empty. Here's what it says in the console: Using ...
aikeu
2 years agoHi Naccy,
May I know what is the board which you are using?
I see that there is something is different from my side as compared to your logs:
Using cable "DE-SoC on 10.107.209.7:3589 [3-1.2]", device 2, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Anyway I suspect that you are using the wrong example project for your board.
Try to find an example project for the board which you are using for reference to run:
Aik Eu
