15 years ago"No CFI table found at address 0x00000000" with S29GL064A flash
hi,
I get "No CFI table found at address 0x00000000" with my custom board using S29GL064A flash. this board was working during 2 years. When I want to program its flash via JTAG (and Nios II), I get the error.
# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x01a03338
--id=1759304877 --timestamp=1223978176 --debug "cfi_flash.flash"
Using cable "ByteBlasterII ", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x01A03338:
verified
Original contents (after writing 0xF0 and 0xFF to address 0x00000000):
0: 3A 74 01 04 74 04 C0 04 3A 4C 01 9C 04 FC FF 9C :t..t...:L......
10: 1E FD 3F 9C 3A 24 00 04 3A E4 2E 04 06 24 00 04 ..?.:$..:....$..
20: C4 FF 7F 05 3A E4 2E 04 06 0F 00 04 3A 8C 07 34 ....:.......:..4
30: 3A E4 2E 04 06 0C 00 04 3A 8C 09 34 26 04 00 1C :.......:..4&...
40: 26 FF 7F 1D 3A E4 2E 04 06 0D 00 04 06 F5 3F 04 &...:.........?.
Contents after writing 0x98 to address 0x000000AA:
Same after writing 0x0098 to address 0x00000154:
0: 00 04 00 04 00 04 00 04 00 04 00 04 00 04 00 04 ................
10: 00 04 00 04 00 04 00 04 00 04 00 04 00 04 00 04 ................
20: 51 04 52 04 59 04 02 04 00 04 40 04 00 04 00 04 Q.R.Y.....@.....
30: 00 04 00 04 00 04 27 04 36 04 00 04 00 04 07 04 ......'.6.......
40: 07 04 0A 04 00 04 03 04 05 04 04 04 00 04 17 04 ................
Contents after writing 0x00000098 to address 0x000002A8:
Same after writing 0x98 to address 0x00000055:
Same after writing 0x0098 to address 0x000000AA:
Same after writing 0x00000098 to address 0x00000154:
Same after writing 0x98 to address 0x00000154:
Same after writing 0x0098 to address 0x000002A8:
Same after writing 0x00000098 to address 0x00000550:
Ignored possible autoselect code 01-7E as no override data
present in section
Ignored possible autoselect code 0401-267E as no override data
present in section
Leaving target processor paused
Have a look at the NIOS manual, It talks about override file for CFI flash. But where Can I get it for my S29G064A ? I tried to search in Forum too. Have you got a work around ? Explications ? Regards.5 Replies
I am verifying deeply SOPC Builder (CFI Flash, Tsetup, Twait, Thold...tri-stated bus) and Quartus design files (connections, Byte_n...)
I am manually writing an override_S29GL064A.txt with all CFI infos from Flash Datasheet. ++ - Altera_Forum
I think you should assign the base address of flash as 0x00000000 in SOPC builder that will solve your issue
regards M Kalaynsrinivas - Altera_Forum
Thanks for answer. The Flash address base is already forced at 0x00000000.
I think my Flash has its CFI table overwritten by bad commands. Is it possible ? - Altera_Forum
Hello mmTsuchi,
I think you have a simple hardware problem: it seems that D10 of your data bus has no connection to the Flash. Search for soldering problems and look if D10 is configured to the right I/O pin... - Altera_Forum
Pin D10 problem because I get "0x04" data ? I hadn't thought before. Thanks you very much for reading, observing, answering and giving the clue (1.5 years after ;-))
I had an oxidation on few boards, I will look at...
