19 years agono boot over nfs
Hello! My configuration worked well with initramfs. Now i like to boot over NFS. I did everything like in "NFSFileSystem" and I can mount the NFS in the linux booted with initramfs. Further I h...
19 years agoYes, you should not enable both jtag and uart as "support for console" in kernel config.
You should choose only one of them. see the wiki, http://nioswiki.jot.com/wikihome/operating...nux/linuxconfig (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/linuxconfig) <div class='quotetop'>QUOTE </div> --- Quote Start --- if you use serial uart (with a 9-pin RS-232C cable) on a terminal emulator such as minicom or ckermit, [*] Nios serial support [*] Support for console on Nios UART [ ] Altera JTAG UART support[/b] --- Quote End --- Do you have /dev/console ? I uploaded a rootfs which I used for the test. http://nioswiki.jot.com/wikihome/operating...s-nios2.tar.bz2 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/nfsfilesytem/rootfs-nios2.tar.bz2) In user config, Core Applications ---> [*] init [*] enable console shell Then the init will open /dev/console for a shell. If you do not select "enable console shell " or you do not have /dev/console, then you have to add a terminal to inittab.
