19 years agono boot over nfs
Hello! My configuration worked well with initramfs. Now i like to boot over NFS. I did everything like in "NFSFileSystem" and I can mount the NFS in the linux booted with initramfs. Further I h...
19 years agowhich console device do you use ? jtag or rs232?
In kernel menuconfig, you should select either jtag uart or serial uart for console device (but not both). Device Drivers ---> Character devices ---> Serial drivers ---> if you use jtag uart (with a USB Blaster cable) on a nios2-terminal, [ ] Nios serial support [*] Altera JTAG UART support [*] Support for console on Altera JTAG UART if you use serial uart (with a 9-pin RS-232C cable) on a terminal emulator such as minicom or ckermit, [*] Nios serial support [*] Support for console on Nios UART [ ] Altera JTAG UART support The console device will use /dev/console node. Yes, you need to create all /dev nodes or copy them from initamfs. Do you get the shell prompt?
