sateesh999
2 years agoniso ii simple server build issue
Hi , i am working with cyclone 10gx FPGA series, I was trying to create a ethernet MII interface with Nios ii eclipse .i was trying to build one simple socket ping project in Niosii eclipse i am un...
tehjingy_Altera
2 years agoHi Sateesh
Could you try adding the memory to at least 500KB?
Please make sure that you are increasing the size of the onchip_memory2_0.
You will need to regenerate the project and generate the BSP again before compiling.
Jingyang, Teh
sateesh999
2 years agohi Jingyang,
Hi tried the given solution now able the generate the .elf ,but it not running on the hard for ping condition, could we connect one small section to address the issue any thing do we to add modification in code as per my phy chip ADIN1200CCP32Z. to make it for simple socket ping purpose
i am awaiting for your response
Venkata Sateesh
