niso ii simple server build issue
Hi
I believe we had a call previously arrange by your FAE regarding this issue.
This problem is due to the generated file format was changed in newer Quartus versio.
Could you try to change the line that you are facing error to the line below(line 39, tse_my_system.c) :
TSE_SYSTEM_INT_MEM_NO_SHARED_FIFO(ETH_TSE_0, 0, MSGDMA_1_TX, MSGDMA_0_RX, TSE_PHY_AUTO_ADDRESS, ADDITIONAL_PHY_CFG)
I managed to get it to compile successfully but meet an error in the elf size.
Jingyang, Teh
Hi Jing yang, Teh,
Thanks for reply for issue ,could you let us known, how we can resolve the ELF fit as of now i am newly working on this Nios II Eclipse, you have better understanding about this issue as per our discussion . Could you tell me any one solution to resolve the issue
i am awaiting for your response
Thanks, Regards
Venkata Sateesh
