22 years agonisii sdk shell problem
I am unable to use the niosii sdkshell as well as the sopc builder. The niosii shell gives me the following errors. bash: grep: command not found. Do i have to remove thenios 1 installat...
22 years agoNot a bad idea getting rid of everything that was for NIOS I. The instruction sets are completely different so I don't think you want to try to have a mix on your system.
When I start up the command prompt shell, I get an error message but then after I get a second say to ignore the first one. I wouldn't bother with the old shell if you can avoid it. The new IDE although kinda tricky to use at first is much nicer.
