Broddo
1 year agoNIOSV/g with FPU: inconsistent calculation results
I'm using a NIOSV/g with FPU enabled in a MAX10 project. The project involves heavy use of float point calculations, hence the need for the FPU. I noticed some occasionally inconsistent results in th...
Broddo
1 year agoMy apologies again for the delay in responding. Yes I can confirm that the work-around suggested by @LYGOOI does address the problem - the FPU is producing consistently correct results now, so thanks for this!
However, disabling caching is a big trade off for my project as I'm executing in place from external flash. I'll need to profile this to determine if FPU without cache is more performant than soft-float with cache. For now, I'm working with the latter and will wait for the fix in a coming release.
Thanks once again,
Broddo
