NiosV Ashling GDB "Debugger disconnected, closed connection to 127.0.0.1 on port ..."
I got this message when trying to Run or Debug a NiosV from Ashling Eclipse tools.
Ashling GDB Server for RISC-V (ash-riscv-gdb-server).
v22.3.2, 19-Aug-2022, (c)Ashling Microsystems Ltd 2022.
Initializing connection ...
Checking for an active debug connection using the selected debug probe (SN: 1):
Cannot set the JTAG frequency, continuing with auto adjust mode
Connected to target device "" using USB-Blaster-2 (1) via JTAG at 15.00MHz.
Info : Active Harts Detected : 1
Info : [0] System architecture : RV32
Info : [0] Number of hardware breakpoints available : 1
Info : [0] Number of program buffers: 8
Info : [0] Number of data registers: 2
Info : [0] Memory Access -> Program buffer
Info : [0] Memory Access -> Abstract access memory
Info : [0] CSR & FP Register Access -> Abstract commands
Waiting for debugger connection on port 50991 for core 0.
Press 'Q' to Quit.
Got a debugger connection from 127.0.0.1 on port 50991.
[0x10000] Internal error. Abstract command execution failed: An abstract command is currently being executed.
Debugger disconnected, closed connection to 127.0.0.1 on port 50991.
Quitting (Ctrl + C)...
It turned out to be that the FPGA clock source to the NiosV debug port was lower than the JTAG_CLOCK frequency.
(Same problems would apply to JTAG UART and other things connected via the SLD TAP(SystemLevelDebug TestAccessPort))
Solutions:
- Increase Clock source in your FPGA design
- Lower JTAG_CLOCK speed on the PC
- hareesh
pleased follow bellow document
- hareesh
