17 years agoNios+PCI doesn't work together, help.
I create Nios+PCI compiler (PCI target 32-bit) system on Cyclone II. When PCI is connected, Nios doesn't load any software, but works good without PCI. I've made PCI in reset, without clk - doesn't h...
17 years agoI reduced Nios clock frequency (from 66MHz to 33), and the system started good. So I consider this problem is due to internal routing timings problem.
