17 years agoNios+PCI doesn't work together, help.
I create Nios+PCI compiler (PCI target 32-bit) system on Cyclone II. When PCI is connected, Nios doesn't load any software, but works good without PCI. I've made PCI in reset, without clk - doesn't h...
17 years agoI'm also using Nios II + PCI core on Cyclone III but I instantiated the PCI separately from the SOPC just for future flexibility, and everything works well. Check in SOPC Builder to make sure your PCI core's Avalon MM Master to not connected to the CPU core at all, and that it should be connected to the proper Avalon MM Slave. (Otherwise, it wouldn't be able to generate SOPC.)
