20 years agoNiosII/f fitting into UP3 and the leading zero tut
Could you help me anyone for these questions? I have two question here Firstly, Currently, I am following NiosII custom instruction tutorial 'the leading zero' one. I am using UP...
20 years agoThe cache is not implemented using Logic Elements but instead uses the RAM blocks. Take a look at the "Total Memory Bits" line in the compilation report summary. Also, in the Resource section of the fitter report there is information on how much memory bits or RAM blocks certain parts of the design are using.
