20 years agoNIOSII RST pin
Dear guys,
I would like to implement a reset of NIOS II processor by software. So I have included by SOPC builder a simple output PIO which is directly connected to the processor RST pin. When I drive this PIO with a LOW state of 20 us (and I'm sure I drive it because I can show it on a scope) I expect NIOS II makes a reset. But it doesn't happen !!! Any ideas ? Best Regards /Alessandro Strazzero5 Replies
If you just want a software reset then
1. disable all IRQs (if you use any) 2. use goto *((void**) NIOS2_RESET_ADDR); to jump to the reset address of the NIOS. NIOS2_RESET_ADDR is defined at system.h, so don't forget to # include <system.h> This will ONLY reset the CPU, NO reset for any of the peripherals !! Hope this helps, Klaus - Altera_Forum
How can I reset my processor from inside the VHDL code without it resetting all peripherals ?
I have a top entity VHDL which has an instance of the Nios II system (which was generated by SOPC builder), connected to various custom VHDL modules. I want the VHDL to supervise processor operation and restart it in case anything goes wrong. How can this be achieved ? - Altera_Forum
--- Quote Start --- originally posted by eliben@Sep 6 2006, 06:05 AM how can i reset my processor from inside the vhdl code without it resetting all peripherals ?i have a top entity vhdl which has an instance of the nios ii system (which was generated by sopc builder), connected to various custom vhdl modules. i want the vhdl to supervise processor operation and restart it in case anything goes wrong. how can this be achieved ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18094)
--- quote end ---
--- Quote End --- I think Nios V6.0 provides a separate CPU reset signal...
--- Quote Start --- originally posted by stonie+sep 6 2006, 04:35 am--><div class='quotetop'>quote (stonie @ sep 6 2006, 04:35 am)</div>--- quote start ---
<!--quotebegin-eliben@Sep 6 2006, 06:05 AM how can i reset my processor from inside the vhdl code without it resetting all peripherals ?
--- quote end ---
--- Quote End --- I think Nios V6.0 provides a separate CPU reset signal... <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18102)</div> [/b] --- Quote End --- Thanks. Is there a way, however, to do it in Nios 5 ? It doesn't have to be an "officially supported way".
Hi Eliben,
We have applications that sometimes need to restart the CPU. Stonie's method of killing the IRQs and jumping to the reset address works ok for us on version 5.0 but I would like to add a little to what he says. As well as disabling the global IRQ it is best to disable all the individual IRQs on the peripherals too. I think Stonie meant this but didn't make it quite clear. This ensures that when the system wakes up again there are no 'pending' interrupts that get serviced before you're ready for them, or have even installed them. Banx.
