11 years agoNiosII, No ELF file path has been selected
Hello everyone ,
I written a PID controller in NiosII, hello_world_small,yesterday, and everyting was OK. I change some codes just now, and I get message : Errors(3 items) address 0xbfdc of PID1.elf section,'bss' is not withinregion'onchip_memory' address 0xbdfc of PID1.elf section ,'onchip_memory' is not within region'onchip_memory' make:***[PID1.elf]Error 1 And I check the Run configurations,the message is : No ELF file path has been selected. What's going on?:( How to generate the ELF file?:confused:9 Replies
Could you please give a Screenshot of your QSYS-System and from the configuration of the NIOS inside the QSYS-System?
I think there could be the Problem. If not, please send a Screenshot of the BSP-Editor (Linker-Script-Tab). If your Project is error free, then an elf-File will be created and could be seen under Run Configurations. - Altera_Forum
Can you pleas also attach the configuration of the NIOS to see the reset and exception vectors?
I was failed to upload the screenshot.
Reset Vector Reset vector memory: onchip_memory.s1 Reset vector offset: 0x00000000 Reset vector: 0x00004000 Exception Vector Exception vector memory: onchip_memory.s1 Exception vector offset: 0x00000020 Exception vector: 0x00004020 - Altera_Forum
Seems to be everything okay.
Could you please try make a completely new SW-Project. Sometimes the NIOS EDS is hanging on some old settings... - Altera_Forum
It seems that the only solution is to make a new project
so it is solved with a new SW-Project?
New NiosII application and BSP from template.
