11 years agoNiosII memory reservation
Hello guys, I have a system running a NiosII processor. In my Qsys system I have connected one port of a dual-port-onchipmem to the Nios data master port and the second port has been exported...
11 years ago --- Quote Start --- Declare dataset_ptr as a global variable, as you have done, but initialize it from main(). e.g.
volatile uint8_t * dataset_ptr;
void main(void)
dataset_ptr = (volatile uint8_t*) alt_remap_uncached(ONCHIP_DATASET_DP_RAM_BASE,ONCHIP_DATASET_DP_RAM_SIZE_VALUE);
--- Quote End --- By the way I've seent that in the bsp editor, under settings->advanced->hal, there is an option called "enable runtime stack checking". So it seems that is possibile if there is enaugh free memory at runtime. However I've not find yet a good tutorial/guide that explains clearly how to use this feature. Could someone help me ?? In the meantime I will try your solution. Have a nice day !!
