16 years agoNIOSII IDE v10 properties error
Hello, I am running NIOSII IDE v10 with sp1 on a Windows 7 (64 bit) machine. I already have compiled the project in Quartus (also v10sp1) and I built and generated my SOPC. When I go in NIOS, I...
15 years ago --- Quote Start --- Hello, I am running NIOSII IDE v10 with sp1 on a Windows 7 (64 bit) machine. I already have compiled the project in Quartus (also v10sp1) and I built and generated my SOPC. When I go in NIOS, I create the project with the .c and .h files, and I create also the system library with the respective ptf file. When I go to the properties for System Library to change the Timestamp timer, the system clock timer and all the other settings, I see that I do not have that option, i cannot select or modify any of the settings ( some of them don't even appear) I have a Windows Xp machine with v10 Altera and it works fine. And my colleagues that have Windows 7, do not have such problems either. I have tried uninstalling and installing again for 5 times already with no luck! Maybe there is some setting I need to modify? Can anybody help? --- Quote End --- Use "Run As Administrator" option to run NIOS i.e. right-click NIOS icon and select "Run As Administrator". Or you can modify icon's properties to turn on this option permanently (right-click, Properties, Advanced ...). Regards, Jari
