21 years agoNIOSII IDE Multiple source files
Is there an app note or instructions on using multiple source files in NIOS IDE? I have a project that uses multiple "C" files and assmebly files that I need to port over to NIOS IDE. This pr...
21 years agoThanks for your help rugbybloke!!
I did know how to add files to the project as you have suggested but the problem was, it would only compile 1 file and that was my main.c file. Come to find out that if a file name is in all caps like "MISC.C" then it will not compile that file even if it is in the project view. I found that it must be in all lower case text. After I changed all file to lower case all is well know http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
