NiosII booting from on-chip memory
I am trying to boot a NiosII (HAL only, no other bigger OS) on a Cyclone IV directly from the on-chip memory. I have initialized the memory .hex file and included it in my project. I then recompiled the project again. I downloaded the *.sof file to the FPGA. However, the NiosII is not booting.
I want to be able that when I download the *.sof file to the FPGA, the processor should boot by itself (without me having to manually download the software from Eclipse) Would anyone have any suggestions for me?18 Replies
--- Quote Start --- A timing unconstrained design can lead to inconsistent results from one compile to the next. I have personnaly benefitted from the time quest users guide posted by user rysc on the altera wiki. --- Quote End --- Could you provide an explicit link :D please ? - Altera_Forum
--- Quote Start --- Could you provide an explicit link :D please ? --- Quote End --- http://www.alterawiki.com/wiki/timequest_user_guide - Altera_Forum
--- Quote Start --- If you have the nios JTAG debugger enabled I think it 'steals' the reset vector. Try removing it. ISTR problems with the JTAG debugger when downloading over PCIe (which is what we do). I think there is a separate JTAG to avalon master that can be used to access memory - useful for debug. With the nios soft-reset exposed that could be used for software download. --- Quote End --- I did your suggestion. The same behaviour. The NiosII does not start when the *.sof is downloaded via JTAG. It just hangs. - Altera_Forum
Hello Terrazas,
Did you manage to solve your problem ? I am having the same problem. How did you convert your elf-file to a hex-file which could be included in Quartus. I use the following: elf2hex --little-endian-mem --input="C_bootloader.elf" --output="C_bootloader.hex" --base=0 --width=32 --end=0x3fff --record=4 --lower When I use SignalTap to look at the processor-signals I don't see any processor activity. It looks like it is still in reset. Regards, Wamor - Altera_Forum
Actually, you don't need to explicitly perform the elf2hex. You can just run "make mem_init_generate" at the app directory and the hex files will be generated for you under a mem_init folder. You should be able to find a QIP file inside the folder. In your Quartus GUI, you can just add the qip file as part of the Quartus project, re-compile in Quartus and the sof generated from the compilation should be able to run after FPGA is configured.
--- Quote Start --- Actually, you don't need to explicitly perform the elf2hex. You can just run "make mem_init_generate" at the app directory and the hex files will be generated for you under a mem_init folder. You should be able to find a QIP file inside the folder. In your Quartus GUI, you can just add the qip file as part of the Quartus project, re-compile in Quartus and the sof generated from the compilation should be able to run after FPGA is configured. --- Quote End --- Did that. It still does not work. Any other ideas? I also tried creating a .hex from the .elf, and setting that as the initialization file in qSys. In either case the hardware is correct in the SOF, but the code is not there. - Altera_Forum
--- Quote Start --- Did that. It still does not work. Any other ideas? I also tried creating a .hex from the .elf, and setting that as the initialization file in qSys. In either case the hardware is correct in the SOF, but the code is not there. --- Quote End --- Review the fitter report and the Quartus messages from your compile. Does it say it is using your initialization file for that M9K memory? - Altera_Forum
Probably you can attached your Quartus Project/ Qsys system and I can take a quick look.
