11 years agoNiosII booting from on-chip memory
I am trying to boot a NiosII (HAL only, no other bigger OS) on a Cyclone IV directly from the on-chip memory. I have initialized the memory .hex file and included it in my project. I then recompiled ...
11 years ago --- Quote Start --- If you have the nios JTAG debugger enabled I think it 'steals' the reset vector. Try removing it. ISTR problems with the JTAG debugger when downloading over PCIe (which is what we do). I think there is a separate JTAG to avalon master that can be used to access memory - useful for debug. With the nios soft-reset exposed that could be used for software download. --- Quote End --- I did your suggestion. The same behaviour. The NiosII does not start when the *.sof is downloaded via JTAG. It just hangs.
