reubengoh
2 years agoNiosII booting from on-chip memory SPI issue
Hi all, I am using quartus prime 19.1 lite, and I am trying to load a simple SPI program that sends SPI commands using NIOS II processor. The board that I am using is DECA Max10 Development Board. I...
- 2 years ago
Hi all,
Just an update to this issue.
The problem has been resolved by disabling the alt_printf statement in my C code. My .pof works now, and it can send the spi commands after power cycling the board.
My guess is that as there is no communication between the board and the nios2 terminal, the alt_printf pointer got lost when executing the function. Hence when loading .pof, all alt_printf must be disabled.
Reuben Goh
wwanalim_intel
Contributor
2 years agoHi,
Will send the work scenario later. In the mean time, can I know if you have additional board to test the file with?
Can you also test with sof + elf file manually and see the niosII terminal console if it run continuosly?
Fathulnaim
