NiosII booting from on-chip memory SPI issue
- 2 years ago
Hi all,
Just an update to this issue.
The problem has been resolved by disabling the alt_printf statement in my C code. My .pof works now, and it can send the spi commands after power cycling the board.
My guess is that as there is no communication between the board and the nios2 terminal, the alt_printf pointer got lost when executing the function. Hence when loading .pof, all alt_printf must be disabled.
Reuben Goh
I've got a question relating to this document below as well.
When booting NIOS II from on-chip memory (RAM), why does the hardware design (attached below) indicate in this document to include the on-chip flash IP.
Anyway I tried to use this hardware design as well in the document, but still had the same issue with my SPI.
Reuben Goh
