reubengoh
2 years agoNiosII booting from on-chip memory SPI issue
Hi all, I am using quartus prime 19.1 lite, and I am trying to load a simple SPI program that sends SPI commands using NIOS II processor. The board that I am using is DECA Max10 Development Board. I...
- 2 years ago
Hi all,
Just an update to this issue.
The problem has been resolved by disabling the alt_printf statement in my C code. My .pof works now, and it can send the spi commands after power cycling the board.
My guess is that as there is no communication between the board and the nios2 terminal, the alt_printf pointer got lost when executing the function. Hence when loading .pof, all alt_printf must be disabled.
Reuben Goh
wwanalim_intel
Contributor
2 years agoHi,
The start address on onchip_memory2_0.hex is based on the start address in Platform Designer system.
If it starts with 2000_0000, then it is mostly likely the OCRAM in Platform Designer starts from 0x2000_0000.
- reubengoh2 years ago
I see, noted. Thanks!
