16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoMay seem like a silly question but I ask because when using inc of 8 and writing
data=addr to the given addr then values are all unique and read value = written value. But with 8 then the memory span seems incorrect and I can't go beyond 0x10000000 else read all F's. It also does not seem logical to use 8 as I believe we are using byte addressing and a 32DIRECT access would hit 4 of these byte addresses at a time. However, when using 4x addressing there is 2x duplication between subsequent addresses when reading back. There could be timing issues relating to this but I wanted to make sure that I am at least doing the right thing in the NIOS code first. Thank-you.
