16 years agoNiosII 9.1 Import Error: Makefile is not Software Build Tools compatible
Hi, I am a makefile novice. I just completed re-making our library makefile based on the nios2-lib-generate-makefile command we were previously using IDE generated commands that were no longer sup...
11 years agoLooks like you also have to set the CREATE_LINKER_MAP variable.
