16 years agoNiosII 9.1 Import Error: Makefile is not Software Build Tools compatible
Hi, I am a makefile novice. I just completed re-making our library makefile based on the nios2-lib-generate-makefile command we were previously using IDE generated commands that were no longer sup...
16 years agoAdd the following to your makefile. Also make sure it's called Makefile and not makefile.
# -------------------------------------------------------------------------------# Following line needs to be included so the eclipse environment recognises# the project and imports it. Go figure. CREATE_ELF_DERIVED_FILES := 0 From memory it also works with a# in front of CREATE go figure. Wasted a couple of hours of my life figuring this crap out.
