21 years agoNiosII & objcopy ? problem
Hi there, i do a migration to NiosII , for now nothing problem except one., why when i use objcopy to transform and .out file to Binary the bin files have an increasead size (it is filled wit...
21 years agoHi JjLeto,
Has your memory map changed? Or have you moved your code to flash? You probably have a large "hole" between a few of your sections that's being filled with 0. Check your .out file with objdump: $ nios2-elf-objdump -h file.out You may need to provide a few load addresses in your linker script. Regards, --Scott
