21 years agoNIOSII - Write output to Dev kit LCD
I am trying to switch over to eCos from MicroC/OS-II. I have succesfully installed eCos for NIOS 5.0. I have built and run the eCos hello example. I am now trying to modify the hello example ...
21 years agoAn easier way to do this is to just include altera_avalon_pio.h, and add the compiler flags:
-I'$(SOPC_KIT_NIOS2)'/components/altera_avalon_pio/inc -I$(PREFIX)/include/cyg/hal. That way you can continue to use the same macros you would have used in the Altera HAL or MicroC/OS-II. I thought that's what you had previously said you were doing. Also, I just noticed that you were adding: -I'$(SOPC_KIT_NIOS2)'/components/altera_avalon_lcd_16207/inc -I$(PREFIX)/include/cyg/hal to get the LCD working. This should not be necessary.
