21 years agoNIOSII - Write output to Dev kit LCD
I am trying to switch over to eCos from MicroC/OS-II. I have succesfully installed eCos for NIOS 5.0. I have built and run the eCos hello example. I am now trying to modify the hello example ...
21 years agoTo use the LCD you need to have the "hardware serial device drivers" option enabled. This is located under the "Serial device drivers" folder in configtool.
This is a little unintuitive - but unfortuanely it's the eCos way of dealing with these devices...
