21 years agoNIOSII - Write output to Dev kit LCD
I am trying to switch over to eCos from MicroC/OS-II. I have succesfully installed eCos for NIOS 5.0. I have built and run the eCos hello example. I am now trying to modify the hello example ...
21 years agoHi jkealty,
Make sure the Compact Flash card is not plugged into it's socket. Due to a hardware constraint on the Nios evaluation boards, you cannot have the LCD and Compact Flash plugged in simultaneously.
