21 years agoNIos5.0 Modelsim trouble !
I try to simulate in Modelsim 6.0 new Nios5.0 (low_cost_1C20 example )
My steps is 1. Open and genarate low_cost_1C20 example with Modelsim project 2. Run IDE 3. Create Hello leds example 4. In system liblary properties set "Modelsim only , no hardware support" 5. Build software 6. Start in IDE (RUN->RUN), press "new" Button after this press "RUN" button 7. MOdelsim starts 8. in Modelsim i press (Tools->Execute macro) and execute "setup_sim.do" 9. In modelsim console write "s" 10. after previous proccess write "w" and timing diagramm starts 11. Next i write "run 500 us" AND SIMULATING STOPS IN FILE "cpu_test_bench.v" in "$stop" string I comment this strings in the file and try run again - result - program code is not working !!!!!!!11 In previous version that way work just fine but what happen in new version ??????????2 Replies
Can you please paste some of the lines of code around the $stop in cpu_test_bench.v so I can see why it is stopping?
What software are you running? You might have accidentally executed a special instruction variation in the CPU used to stop our simulations for internal testing purposes. You can always just try running again in modelsim to continue execution. - Altera_Forum
I have also encounter this problem, The modelsim console show the following info:# # ************************************************************# This testbench includes an SOPC Builder Generated Altera model:# 'sdram_test_component.v', to simulate accesses to SDRAM.# Initial contents are loaded from the file: 'sdram.dat'.# ************************************************************# 100970 ns: WARNING: cpu_test_bench/M_wr_data_unfiltered is 'x'# 100990 ns: ERROR: cpu_test_bench/W_wr_data is 'x'
If i comment the lines in cpu_test_bench.v, the nios seems not work.Any one can tell me how to solve this problem?
