13 years agonios2configgen for qsys?
Hello all, I'm looking for a way to generate eCos configuration out of the design done in Qsys. I was able to successfully generate working eCos examples which come with nios2ecos. However...
13 years ago --- Quote Start --- AFAIK this tool has never been ported to the new build environment based on .sopcinfo files. So if you plan to use eCos, you are stuck with SOPC Builder, or you need to port the tool yourself. --- Quote End --- Ok, thanks Daixiwen. I suspected that as it seems, that eCos discussion here is virtually dead. Anyone knows why the eCos is no longer supported? Has it been replaced with another thing? Am I missing something? Michal
