16 years agonios2 with nommu of the test-nios2 branch booting trapped with the ghost
Oh on fire, who can help me, man? this is the boot info below,in my custom Cyclone II board for nios2, I thought I have meet a ghost. [NiosII EDS]$ nios2-download -g zImage Using cable "USB...
16 years ago --- Quote Start --- make ARCH=nios2 -C vendors romfs.post make[1]: Entering directory `/home/matt/nios2-linux/uClinux-dist/vendors' make -C /home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /home/matt/nios2-linux/uClinux-dist/vendors/vendors-common.mak romfs.post make[2]: Entering directory `/home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[2]: Nothing to be done for `romfs.post'. make[2]: Leaving directory `/home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[1]: Leaving directory `/home/matt/nios2-linux/uClinux-dist/vendors' find /home/matt/nios2-linux/uClinux-dist/romfs/. -name CVS | xargs -r rm -rf [ -d /home/matt/nios2-linux/uClinux-dist/images ] || mkdir /home/matt/nios2-linux/uClinux-dist/images make ARCH=nios2 -C vendors image make[1]: Entering directory `/home/matt/nios2-linux/uClinux-dist/vendors' make -C /home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /home/matt/nios2-linux/uClinux-dist/vendors/vendors-common.mak image make[2]: Entering directory `/home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2' [ -d /home/matt/nios2-linux/uClinux-dist/images ] || mkdir -p /home/matt/nios2-linux/uClinux-dist/images chmod -R +x /home/matt/nios2-linux/uClinux-dist/romfs/bin rm /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz rm: cannot remove `/home/matt/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz': No such file or directory make[2]: [image] Error 1 (ignored) LDFLAGS="" make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/matt/nios2-linux/uClinux-dist/../linux-2.6 O=/home/matt/nios2-linux/uClinux-dist/linux-2.6.x zImage make[3]: Entering directory `/home/matt/nios2-linux/linux-2.6' no emulation specific options. CHK include/asm-nios2/nios2.h perl -I/home/matt/nios2-linux/linux-2.6/arch/nios2/scripts /home/matt/nios2-linux/linux-2.6/arch/nios2/scripts/gen_nios2.h.pl cpu sdram < /home/matt/Desktop/nios_lcd.ptf > include/asm-nios2/nios2.h.tmp; if [ -r include/asm-nios2/nios2.h ] && cmp -s include/asm-nios2/nios2.h include/asm-nios2/nios2.h.tmp; then rm -f include/asm-nios2/nios2.h.tmp; else echo ' UPD include/asm-nios2/nios2.h'; mv -f include/asm-nios2/nios2.h.tmp include/asm-nios2/nios2.h; fi Using /home/matt/nios2-linux/linux-2.6 as source for kernel GEN /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/Makefile CHK include/linux/version.h CHK include/linux/utsrelease.h SYMLINK include/asm -> include/asm-nios2 CALL /home/matt/nios2-linux/linux-2.6/scripts/checksyscalls.sh CHK include/linux/compile.h LD vmlinux.o MODPOST vmlinux.o WARNING: modpost: Found 2 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o LD init/built-in.o LD vmlinux SYSMAP System.map OBJCOPY arch/nios2/boot/vmlinux.bin GZIP arch/nios2/boot/vmlinux.gz LD arch/nios2/boot/compressed/piggy.o LD arch/nios2/boot/compressed/vmlinux OBJCOPY arch/nios2/boot/zImage Kernel: arch/nios2/boot/zImage is ready make[3]: Leaving directory `/home/matt/nios2-linux/linux-2.6' cp /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/boot/zImage /home/matt/nios2-linux/uClinux-dist/images/zImage make[2]: Leaving directory `/home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[1]: Leaving directory `/home/matt/nios2-linux/uClinux-dist/vendors' matt@matt-desktop:~/nios2-linux/uClinux-dist$ matt@matt-desktop:~/nios2-linux/uClinux-dist$ --- Quote End --- to be finished. this is a terrific giant post I cite on the internet from my terminal
