16 years agonios2 with nommu of the test-nios2 branch booting trapped with the ghost
Oh on fire, who can help me, man? this is the boot info below,in my custom Cyclone II board for nios2, I thought I have meet a ghost. [NiosII EDS]$ nios2-download -g zImage Using cable "USB...
16 years ago --- Quote Start --- make[1]: Leaving directory `/home/matt/nios2-linux/linux-2.6' if [ -f /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/vmlinux ]; then ln -f /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/vmlinux /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/linux ; fi . /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/.config; if [ "$CONFIG_MODULES" = "y" ]; then [ -d /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/modules ] || mkdir /home/matt/nios2-linux/uClinux-dist/linux-2.6.x/modules; make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/matt/nios2-linux/uClinux-dist/../linux-2.6 O=/home/matt/nios2-linux/uClinux-dist/linux-2.6.x modules; fi for dir in lib user ; do [ ! -d $dir ] || make ARCH=nios2 -C $dir || exit 1 ; done make[1]: Entering directory `/home/matt/nios2-linux/uClinux-dist/lib' [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) [ -z "" ] || make -j4 || exit $? [ -z "" ] || (cd /home/matt/nios2-linux/uClinux-dist/staging; chmod 755 ./usr/lib/lib*.so*; chmod 644 ./usr/lib/lib*.la ./usr/lib/lib*.a; sed -i -e "/^libdir=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr/lib':" -e "/^dependency_libs=/s: /usr/lib/: /home/matt/nios2-linux/uClinux-dist/staging/usr/lib/:g" ./usr/lib/*.la; sed -i "/^prefix=/s:=.*:='/home/matt/nios2-linux/uClinux-dist/staging/usr':" ./usr/lib/pkgconfig/*.pc ./usr/bin/*-config; true) make[1]: Leaving directory `/home/matt/nios2-linux/uClinux-dist/lib' make[1]: Entering directory `/home/matt/nios2-linux/uClinux-dist/user' make -j4 /home/matt/nios2-linux/uClinux-dist/prop /home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2/. games init sash || exit $? make[2]: Entering directory `/home/matt/nios2-linux/uClinux-dist/user' [ ! -d "/home/matt/nios2-linux/uClinux-dist/prop" ] || ( touch /home/matt/nios2-linux/uClinux-dist/prop/.sgbuilt_user && make -C /home/matt/nios2-linux/uClinux-dist/prop ) || exit $? make[2]: Nothing to be done for `/home/matt/nios2-linux/uClinux-dist/vendors/Altera/nios2/.'. [ ! -d "games" ] || ( touch games/.sgbuilt_user && make -C games ) || exit $? [ ! -d "init" ] || ( touch init/.sgbuilt_user && make -C init ) || exit $? [ ! -d "sash" ] || ( touch sash/.sgbuilt_user && make -C sash ) || exit $? make[3]: Entering directory `/home/matt/nios2-linux/uClinux-dist/user/games' for i in dummy ; do [ $i = dummy ] || make -C $i || exit ; done make[3]: Entering directory `/home/matt/nios2-linux/uClinux-dist/user/init' nios2-linux-uclibc-gcc -O2 -g -fno-builtin -DCONSOLE_BAUD_RATE=9600 -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/matt/nios2-linux/uClinux-dist -I/home/matt/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/matt/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/matt/nios2-linux/uClinux-dist -I/home/matt/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/matt/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -c -o simpleinit.o simpleinit.c make[3]: Leaving directory `/home/matt/nios2-linux/uClinux-dist/user/games' nios2-linux-uclibc-gcc -O2 -g -fno-builtin -DCONSOLE_BAUD_RATE=9600 -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/matt/nios2-linux/uClinux-dist -I/home/matt/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/matt/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/matt/nios2-linux/uClinux-dist -I/home/matt/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/matt/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -c -o expand.o expand.c make[3]: Entering directory `/home/matt/nios2-linux/uClinux-dist/user/sash' --- Quote End --- to be continued :D
