16 years agonios2 with nommu of the test-nios2 branch booting trapped with the ghost
Oh on fire, who can help me, man? this is the boot info below,in my custom Cyclone II board for nios2, I thought I have meet a ghost. [NiosII EDS]$ nios2-download -g zImage Using cable "USB...
16 years ago --- Quote Start --- CC kernel/posix-cpu-timers.o CC kernel/mutex.o CC fs/namespace.o CC fs/seq_file.o CC kernel/hrtimer.o CC kernel/rwsem.o CC fs/xattr.o CC kernel/nsproxy.o CC kernel/srcu.o CC kernel/semaphore.o CC fs/libfs.o CC fs/fs-writeback.o CC kernel/notifier.o CC kernel/ksysfs.o /home/matt/nios2-linux/linux-2.6/fs/libfs.c: In function `simple_attr_write': /home/matt/nios2-linux/linux-2.6/fs/libfs.c:732: warning: comparison of distinct pointer types lacks a cast CC kernel/pm_qos_params.o CC kernel/sched_clock.o CC fs/pnode.o CC kernel/cred.o CC fs/drop_caches.o CC kernel/async.o CC fs/splice.o CC fs/sync.o CC kernel/irq/handle.o CC kernel/time/timekeeping.o /home/matt/nios2-linux/linux-2.6/kernel/irq/handle.c:428:3: warning:# warning __do_IRQ is deprecated. Please convert to proper flow handlers CC fs/utimes.o CC kernel/irq/manage.o CC fs/stack.o CC fs/fs_struct.o CC kernel/time/ntp.o CC kernel/irq/spurious.o CC fs/no-block.o CC kernel/irq/resend.o CC fs/devpts/inode.o CC kernel/time/clocksource.o LD fs/notify/dnotify/built-in.o LD fs/notify/inotify/built-in.o CC kernel/irq/chip.o LD fs/notify/built-in.o LD fs/partitions/built-in.o LD fs/devpts/devpts.o CC kernel/time/jiffies.o CC kernel/irq/devres.o LD fs/devpts/built-in.o CC fs/proc/nommu.o CC kernel/time/timer_list.o LD fs/quota/built-in.o CC fs/ramfs/inode.o CC kernel/irq/autoprobe.o CC fs/proc/task_nommu.o CC kernel/time/timecompare.o CC fs/ramfs/file-nommu.o CC kernel/irq/proc.o LD kernel/time/built-in.o CC fs/proc/inode.o LD fs/ramfs/ramfs.o LD kernel/irq/built-in.o CC kernel/futex.o LD fs/ramfs/built-in.o CC kernel/rtmutex.o CC fs/sysfs/inode.o CC fs/proc/root.o CC fs/sysfs/file.o CC kernel/up.o CC fs/proc/base.o /home/matt/nios2-linux/linux-2.6/fs/sysfs/file.c: In function `sysfs_read_file': /home/matt/nios2-linux/linux-2.6/fs/sysfs/file.c:146: warning: signed size_t format, size_t arg (arg 3) CC kernel/uid16.o CC kernel/softlockup.o CC fs/sysfs/dir.o CC kernel/hung_task.o CC kernel/rcuclassic.o CC kernel/utsname_sysctl.o CC fs/sysfs/symlink.o CC kernel/time.o CC fs/proc/generic.o CC fs/sysfs/mount.o LD kernel/built-in.o CC fs/sysfs/bin.o CC fs/proc/array.o LD drivers/auxdisplay/built-in.o CC drivers/base/core.o CC fs/proc/proc_tty.o CC fs/sysfs/group.o CC fs/proc/cmdline.o LD fs/sysfs/built-in.o CC drivers/base/sys.o CC drivers/base/bus.o CC fs/proc/cpuinfo.o CC fs/anon_inodes.o CC fs/signalfd.o CC fs/proc/devices.o CC drivers/base/dd.o CC drivers/base/driver.o CC fs/proc/interrupts.o CC fs/proc/loadavg.o CC drivers/base/class.o CC drivers/base/platform.o CC fs/proc/meminfo.o CC drivers/base/cpu.o CC fs/proc/stat.o CC drivers/base/firmware.o CC fs/proc/uptime.o CC fs/proc/version.o CC drivers/base/init.o CC fs/proc/kmsg.o CC drivers/base/map.o CC fs/timerfd.o LD sound/built-in.o LD fs/proc/proc.o CC drivers/base/devres.o LD fs/proc/built-in.o CC drivers/base/attribute_container.o LD firmware/built-in.o CC fs/eventfd.o CC drivers/base/transport_class.o LD drivers/base/power/built-in.o CC net/nonet.o CC drivers/base/dma-mapping.o CC fs/binfmt_script.o LD net/wireless/built-in.o LD drivers/block/built-in.o LD net/built-in.o CC fs/binfmt_flat.o LD drivers/cdrom/built-in.o LD drivers/base/built-in.o CC drivers/char/mem.o LD drivers/clocksource/built-in.o LD drivers/firmware/built-in.o LD drivers/gpio/built-in.o LD drivers/gpu/drm/built-in.o LD drivers/gpu/built-in.o LD drivers/i2c/algos/built-in.o LD drivers/i2c/busses/built-in.o LD drivers/idle/built-in.o LD drivers/i2c/chips/built-in.o LD drivers/i2c/built-in.o LD drivers/ieee1394/built-in.o LD drivers/lguest/built-in.o CC drivers/char/random.o LD drivers/macintosh/built-in.o LD fs/built-in.o LD drivers/mfd/built-in.o LD drivers/media/common/tuners/built-in.o LD drivers/media/common/built-in.o LD drivers/misc/eeprom/built-in.o LD drivers/misc/built-in.o /home/matt/nios2-linux/linux-2.6/drivers/char/random.c: In function `write_pool': /home/matt/nios2-linux/linux-2.6/drivers/char/random.c:1078: warning: comparison of distinct pointer types lacks a cast LD drivers/media/video/built-in.o LD drivers/media/built-in.o LD drivers/net/wireless/built-in.o LD drivers/net/built-in.o LD drivers/platform/built-in.o CC drivers/serial/serial_core.o CC drivers/char/tty_io.o CC drivers/video/fb_notify.o CC lib/bcd.o LD drivers/video/backlight/built-in.o CC lib/div64.o LD drivers/video/display/built-in.o LD drivers/video/built-in.o CC drivers/serial/altjuart.o CC lib/sort.o CC lib/parser.o CC drivers/serial/altuart.o CC lib/halfmd4.o /home/matt/nios2-linux/linux-2.6/drivers/serial/altuart.c:528: warning: 'altera_uart_remove' defined but not used CC drivers/char/n_tty.o CC lib/debug_locks.o LD arch/nios2/lib/built-in.o LD drivers/serial/built-in.o CC arch/nios2/lib/checksum.o CC lib/random32.o CC lib/bust_spinlocks.o CC arch/nios2/lib/memcpy.o CC lib/hexdump.o CC arch/nios2/lib/string.o CC lib/kasprintf.o AR arch/nios2/lib/lib.a CC drivers/char/tty_ioctl.o CC lib/bitmap.o CC drivers/char/tty_ldisc.o CC drivers/char/tty_buffer.o CC drivers/char/tty_port.o CC lib/scatterlist.o CC drivers/char/pty.o CC drivers/char/misc.o CC lib/string_helpers.o CC lib/iomap_copy.o CC lib/devres.o CC lib/find_last_bit.o CC lib/hweight.o LD drivers/char/built-in.o CC lib/kernel_lock.o LD drivers/built-in.o CC lib/bitrev.o HOSTCC lib/gen_crc32table CC lib/argv_split.o CC lib/zlib_inflate/inffast.o CC lib/cmdline.o CC lib/zlib_inflate/inflate.o CC lib/ctype.o CC lib/zlib_inflate/infutil.o --- Quote End --- to be continued :D
