20 years agoNIOS2 Tristate PIO Direction Whatever...
hi, i wonder if there is someone else who experienced this "PROBLEM":
if i use a 32-bit pio (mapped to some pins on the PROTO2 connector), the PIO-Direction register can be found at "BASE+0x04". fine. if i use a 12-bit pio it is at "BASE+0x02"!!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif the handbook only says: data = offset 0, direction = offset 1. there should be the mark, that the "offset" (which is fix for me if i talk about offset) may VARY depending on the width of the IO... i remember the old NIOS, the dir-reg was ALWAYS at base+0x04, no matter. i tried to port the old module for the NIOS2, it didnt work. - so the PIO-Component has changed as well - thanks altera! greetings, martinNo RepliesBe the first to reply
